Welcome to Club SAITO !
#8553
Hi Guys,
I have a 2mtr Cap 231 with a saito 120s in it and it's got good performance, but limited vertical pull. Can do nice big loops but can't hover or keep climbing up. I am thinking of replacing with a 150bk I have seen come up for sale. Would I expect a marked increase if I switched to the 150?
Cheers.
Cheers.
#8555
![](/forum/images/badges/premium_member.png)
Im sorry about the confusion... the 85 Deg was the temp outside, (air temp). didnt check the engine temp. And im still running the plug that came with it.
#8556
Hi there, so I should not expect this plane to be transformed by replacing the Saito 120 with a 150? i.e. do you believe I will see a marked difference?
Cheers
Cheers
#8558
MB, CANADA
At 85 degrees and high humidity you will notice a drop in power, as there is less oxygen in the air therefore you can't burn as much fuel.
#8560
ORIGINAL: w8ye
There would barely be enough difference for you to notice. You need to go with a Saito 180
That's the answer I was looking for.... thanks! So.. anyone out there got a Saito 180 in good nick that they're looking to offload??
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
#8561
MI
Got the issues with the Saito 150 resolved this evening. Solutions to some of my issues may be obvious to many of you, but I'll share my experience with the forum nonetheless.
Slipped back out to the field this evening after having added a separate fuel dot for the vent. I started with the HS needle open at three turns and had some success getting the engine up over 8K rpms, found the peak and backed the needle back out a touch to lower the rpm. I thought, cool, I have it. I then ran the rpms up a few times and back down. All seemed well until I opened the throttle full and left it there for a minute or so. The engine loaded up and died. I went through this a couple of times, each time resetting the HS needle. I just couldn't figure out what was going on, so I decided to check the LS mixture. As I peered into the cowl, I noticed fuel running out of the carb. I couldn't figure out why the carb was dripping fuel then it dawned on me about the one way check valve I had put in the vent line. I unscrewed the HS needle and got a geyser of pink Omega a good two inches high. I had never used a one way valve before, but thought I wouldn't hurt. Well, with these engines, apparently it does. I was getting so much pressure built up in the tank that carb couldn't properly mix the fuel and air. My issues last week of not being able to unload the engine were due to this blasted valve. Once I took the valve out, the engine ran up great, and I was able to set the HS needle without a hitch.
I ran the engine up a number of times and all seemed well, so I brought it back down to tweak the idle rpm. It seemed to run fine but then would quit. I restarted a few times with the same result. Idle 30 seconds or so then quit. I backed out the LS screw a quarter turn, but that wasn't enough, a little more, and I had a nice consistent idle at 2800. I let it run for a good 10 minutes, occasionally running up the rpms then back down. The Saito was finally dialed in, but I was out of daylight, so the Ultimate has to wait for yet another day for its maiden.
Thanks for all the tips.
ORIGINAL: iflyfisher
I thought I read something on this recently, but I can't seem to find it. I had my CG Ulimate out this evening for its maiden, but I was grounded. I couldn't get the HS needle set. Go figger, this is usually fairly easy, but with my 18x6 prop, I couldn't get the 150 to unload. I started with the HS open about 5 turns and kept closing it a click or two at a time, waiting several seconds each time for the engine to adjust. It wouldn't move much above 7k. I'd get around 4 turns open, and the engine would stall while wide open. It was still blowing heavy smoke, but I thought it must be lean, so I'd open it back up a couple of turns and start over. I ran about three tanks of fuel through, but finally gave up as I kept getting the same results. I had run the engine for about 30 minutes a week ago at no higher than 4k and the HS needle open about 5 turns. I thought I might have to install a smaller prop. Since I've come home, I did some searching, and I saw where at least some of you were running between 2 and 2 1/2 turns open. If that is the case, I wasn't even close. But what I don't know is why the engine was stalling around 4 turns. I didn't want to run this new engine too lean, so I never really got beyond 4 turns.
Do I just go back out with the same 16x8 prop and start tweaking with the HS needle set around 3 turns? Do I put on a smaller prop? If so, what? Idle was terrific. It settled down around 2.8k and would run there indefinately.
Ken
Ken
#8563
NJ
There were a couple of comments a few msgs back about the Saito 125 and props.
I've experimented with a number just last week and keep coming back to the APC 16x6. I'm getting 9100 rpm on 15% nitro and using a digital fish scale this prop packs the most punch in terms of thrust - something like 14 lbs! On another forum, the same consensus was reached - the APC 16x6 consistently provided the most thrust with the Saito 125, so that is easily the best choice if you want to do 3D.
#8564
Can the same be said for the Saito 120s - a 16 x 6 prop is the best choice? Is there much difference in performance between the 125 & 120s?
#8566
thrashin,
I have both and can't tell any difference in the two engines. I have to say that the 1.25 has not been airborne yet. The performance varies between airplanes. To accurately compare, they would have to be tried on the same plane. However, on the bench it doesn't seem to have any more power. The 1.25 is fairly new and seems to like the 15x8 APC better than the 16x6. There is not that much difference in the props. Maybe it will change with more run time.
Jim
Jim
#8567
![](/forum/images/badges/trading_plus_member.png)
OH
ORIGINAL: RC Specialties
thrashin,
Jim
thrashin,
Jim
The 1.20 weighs 10 ounces more than the 1.25!
Let's assume you have two identical engines, spinning identical props, at identical RPM's, mounted in identical planes. The lighter "ready to fly" plane will perform better, simply because it has less mass to move through the air.
Unless you need the extra weight in the nose to balance your plane, the 1.20 will have quite a bit lower performance as compared to the 1.25. This is irregardless of how you measure "performance" - acceleration, vertical flight, 3-D, or whatever.
Whoops! I just thought of one area where heavier weight might be an advantage - if you are trying to see how large a hole you can make in the ground. (Like I have done with a few of my planes!) HA!
#8569
Ken,
You are absolutely correct about the weight issue. You would see a little increase in performance with less weight. Maybe this is where they get the 10% more power. It would have some increase, but I am not convinced it would be a notable difference. Hey, every little bit helps. One thing I have noticed is the fuel consumption. My 1.20 drinks the fuel like crazy. The 1.25 seems better on fuel.
Jim
Jim
#8571
OH
Jim, I think that losing 10 ounces would make quite a difference in a fairly light weight plane.
If we are talking about a six-pound plane, that would be roughly 10% of the total weight. If the plane is eight pounds, it is only about 8%. In a ten-pound plane, it is only 6.5%. So, the heavier the plane, the less you would likely notice a performance increase by losing 10 ounces.
If you can reduce the weight you have to pull around by 8% or more, I think you WOULD notice the difference!
Of course, all of this is pure speculation, since those identical planes I wrote about could never exist. They would both HAVE to be balanced, and the lighter one might require the additional weight up front anyway!
#8573
My Feedback: (66)
NY
Hi All,
I've got a Saito 100 with about 2 hrs runtime on it, 15x6 APC, OS F Plug, using 30% cool power heli fuel. I've slowly tuned the engine to lean it out to where it's been running perfect. Then I had a dead stick. I found that the glow plug had burned out and the muffler had loosened up. I replaced the original Saito plug with an OS F plug and tightened the muffler. After doing this the engine would not idle well. The low end became so rich that I had to turn in the low end screw 3-5 turns. Originally after I first tuned the engine, the low end screw was a little below flush with the throttle arm. Now after retuning, it's very far in, like an 1/8 of an inch. Is ther anything else that could make the low end become so rich all of a sudden??
Larry
Larry
#8574
Ken,
I don't disagree with you. I am going to try it in my Ultimate. With the 1.20 I had to add tail weight. In this case it will make a difference. I will let you know.
Jim
Jim
