Reload this Page >
FokkeRC 1/5 Spitfire MKIX build log
Old 12-16-2020, 03:13 PM
Wyoturbine
Wyoturbine's Avatar
Originally Posted by Lifer
Looks great! How big a fuel tank can you get in her?
Thanks! 32oz is what I’m planning.
Old 12-16-2020, 03:35 PM
Wyoturbine
Wyoturbine's Avatar
Duplicate post
Old 12-17-2020, 08:06 AM
Wyoturbine
Wyoturbine's Avatar
Able to do a little work this morning before I head to work. I picked up a Sierra 1/5 tailwheel bracket and got it installed. I’m not happy with the wheel, tad small. I need to find one 1 3/4” by 7/16 wide.
Old 12-17-2020, 08:14 AM
FlyerInOKC
FlyerInOKC's Avatar
DuBro has one 1.75 in diameter by 0.674 you might be able squeeze in.
https://www.dubro.com/collections/ta...nt=27880739911
Old 12-17-2020, 09:02 AM
Wyoturbine
Wyoturbine's Avatar
Hey I’ll give it a shot, Thanks!
Old 12-17-2020, 09:11 AM
  #31
FlyerInOKC
FlyerInOKC's Avatar
Anytime! Good luck!
Old 12-19-2020, 03:32 PM
  #32
Wyoturbine
Wyoturbine's Avatar
Today I finished skinning the underside of the stabilizer. Then built a saddle and glued it up this afternoon. The upper stringers are glued and I started on the vertical stab. I’m going to do some beefing up here I think, the plans have it built very light(which is good), but I feel it needs a vertical support midway, at least bass stringers vertically. I hate to add any extra weight to the tail, but I feel it needs some structure there.
Old 12-19-2020, 04:29 PM
  #33
FlyerInOKC
FlyerInOKC's Avatar
What brand of laser level are you using there?
Old 12-19-2020, 04:55 PM
  #34
Wyoturbine
Wyoturbine's Avatar
It’s a Qooltec:
https://www.amazon.com/gp/aw/d/B00PQ4PJYC?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B00PQ4PJYC?psc=1&ref=ppx_pop_mob_b_asin_title
Cheap but it works great, I did need to calibrate the crosshairs before use. You can rotate the optical head with a flathead screwdriver, it took 5 minutes of leveling surfaces and then projecting against a leveled crosshair on a wall.
Old 12-19-2020, 08:29 PM
  #35
FlyerInOKC
FlyerInOKC's Avatar
I have a cheapie I bought a number of years back that is self adjusting. It sure help with tail feathers installation.
Old 12-20-2020, 05:42 AM
  #36
Wyoturbine
Wyoturbine's Avatar
That they do! I wish this one self leveled but for $15 it’s not too much trouble.
This morning I started on the elevator halves, The plans have them joined up for single point of operation, but I’m planning to run independent servos for each side, I like the redundancy.
Old 12-21-2020, 12:50 PM
  #37
Wyoturbine
Wyoturbine's Avatar
This morning I finished the left elevator half. I needed a break before doing the right side so I went into the vertical stab. I ended up adding a bass stringer vertically just for some added structure. Finished up the upper saddle and sheeted the vert stab. The forward area needed sanded balsa stock(to many complex curves for the sheeting. Final sand to go on all this but it’s moving quickly. I’ll finish other elevator half tomorrow. Starting to see a spitfire!
Old 12-21-2020, 12:53 PM
  #38
FlyerInOKC
FlyerInOKC's Avatar
Great work!
Old 12-21-2020, 01:17 PM
  #39
nswords
That is one long cowl! will a inline Twin fit, like a DLA64 ?
Old 12-21-2020, 02:42 PM
  #40
Wyoturbine
Wyoturbine's Avatar
Great work!
Thanks!! I received that dubro tailwheel today, it’s about 2-3 mm too thick, I may be able to sand it down on both sides, not sure yet what I’m going to do there yet.
Old 12-21-2020, 02:48 PM
  #41
Wyoturbine
Wyoturbine's Avatar
That’s the exact engine I was wanting to try on this bird, but...if you look through the cowling in those photos you’ll see the firewall, the cowl slides a good 8 inches aft of firewall for the scale location. I measured and length it was going to be too short(I could have relocated the firewall aft) but the biggest problem was the dla’s carbs are side mounted. Along with even a pitts or header style muffler, they would have been sticking outside the cowl all over the place. So I went with the good ole dle-55ra. Nothing exotic, but I know the engine and it’ll pull her just fine at 23-27lbs
Old 12-23-2020, 04:53 AM
  #42
Wyoturbine
Wyoturbine's Avatar
I was able to finish up the elevator halves yesterday, and started on hinging. I also found a tailwheel in an old lot of parts that’s the exact right size.
One problem I’ve ran into is the spinner. The one I was planning to use isn’t quite right, it’s too long. I need a 5” diameter by 5” length. The only mkix style I’ve found in this size is the top flite giant scale mkix spinner. I put a want ad out on regroups, but unfortunately that arf, as well as it’s parts are a rarity. If anyone knows of a 5”x5” scale spitfire spinner I’d love any info/help!
Old 12-23-2020, 05:54 AM
  #43
fokke
fokke's Avatar
Fantastic job you did with this kit !!!
I see taht you find the spinner
Old 12-23-2020, 06:08 AM
  #44
Wyoturbine
Wyoturbine's Avatar
Thanks Rumen! It’s coming along, I was going to talk to truturn or Dave brown about custom spinners. I’ve searched all over and cannot seem to find a scale 5”x5” mkix style. Again the one I have is close, but it’s 1/2” too long and I feel like it’ll be noticeable too long once installed.
Old 12-23-2020, 06:12 AM
  #45
fokke
fokke's Avatar
I made 1/5 spinner by carbone fiber to , but my backplate is made by 3D printer and I can't sell it because I am not sire how strong is the structure. The bacplate is made by PETG ....
Also I made 4 blades prop
Old 12-23-2020, 06:16 AM
  #46
Wyoturbine
Wyoturbine's Avatar
I saw that on your page, beautiful work! It’d be the perfect static display spinner. Hopefully someone has the old top flite spitty spinner laying around in a box they’ll sell me! Or I’ll be going custom. After all the work/time one puts into a kit like this, you really want the lines to look right.
Old 12-23-2020, 06:19 AM
  #47
Wyoturbine
Wyoturbine's Avatar
Do you have plans to build a flying version of that spinner(aluminum backplate)? I’d be your first customer!
Old 12-23-2020, 06:31 AM
  #48
nswords
You should be able to find the necessary accessories
Old 12-23-2020, 06:39 AM
  #49
fokke
fokke's Avatar
I have the all plans of the MK9 spinner but no time to make by aluminium
Old 12-23-2020, 06:53 AM
  #50
FlyerInOKC
FlyerInOKC's Avatar
Have you checked with Dave Brown? They do custom spinners if a stock spinner won't work and they do have a 5" X 5" spinner.
https://www.dbproducts.com/index2.htm
